Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-12-2009, 10:19 PM
tonydeaton tonydeaton is offline
My 96 eclipse problem. help PLEASE!
ok i have a 1996 eclipse given to me by a friend.he was driving one day and it just cut out on him.he started it a few more times then it just quit completely.I got it and took the valve cover off because the seal was bad and noticed that 2 of the seals around the plugs were bad and oil had spilled over into the plugs.so i replaced the seals,plugs,wires,changed the oil, and got a new battery.And it still wont start.its trying hard to turn over, every so often it sounds like its gonna.
So i was wondering if anyone had a suggestion.and if he ran it out of gas which may have happened, what would i need to do to fix that if anything.any feedback would help.
Thank You!
Old 07-13-2009, 09:15 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: My 96 eclipse problem. help PLEASE!
Verify the plug wires are going to the proper plugs, please.
Kris
2012 Genesis Coupe 2.0t
Old 07-13-2009, 04:29 PM
good point ill do that thanks
Old 07-13-2009, 11:44 PM
ok i checked the plugs they look good.i sprayed starter fluid in the intake and it started for 2-5 secs each time.any clue anyone?
Old 07-19-2009, 02:23 AM
InsanelyOdd InsanelyOdd is offline
The only time I had a problem with my eclipse not turning over is when I flooded the spark plugs as well. Did you replace all the plugs?
Old 07-20-2009, 01:45 PM
yea they are all brand new.now im looking at a fuel pump or filter
