Go Back   Automotive Forums Car Chat > Chrysler > Pacifica
Old 07-12-2009, 02:40 PM
djjm3 djjm3 is offline
2007 Pacifica Steering Wheel Shakes
Everytime I hit the brakes The steering Wheel Shakes. I replaced the Tie rod ends on suspect...As well as the brake pads...I still getting the shakes.....Any ideas?
Old 07-20-2009, 08:41 AM
busboy4 busboy4 is offline
Re: 2007 Pacifica Steering Wheel Shakes
Front end shake during braking is typically rotor warp. You might pull them and get them turned, and/or replace them depending on age. Then, make lubricating the caliper slides a regular maintenance item to keep them "floating" which should help normalize the wear on the pads and rotors.
Another simple thing just to eliminate a possible problem - rotate your tires front to back just in case you are dealing with a tire/wheel issue. If the shakes remain, go on with the brake maintenance.
Good luck.
