Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-12-2009, 01:57 PM
dahirolla dahirolla is offline
'93 Camry no compression
I was given a 93 Camry with 199k miles. No compression in 1 and 4, and less than 120 in 2 and 3. I was able to start it twice and ran ragged (Had to manipulate the gas pedal to keep it running) before I put coolant in it, but now it won't start at all.
No evidence of coolant in the oil, or oil in the coolant.
Family sticker says PTV2-2V5FFE4.
I've worked on stuff like alternators and water pumps before, but once it gets inside the engine I'm lost. Can I easily figure out if I have a problem with the head, head gasket, or engine?
The previous owner took good care of the car, so the interior and exterior look great. Only problem is it won't run...lol.
Old 07-13-2009, 11:00 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: '93 Camry no compression
A leak-down test will help with where the air being pumped by the pistons is going...hissing out the exhaust means bad exhaust valves, out the intake manifold/TB means intake valves. Bubble sounds means it's coming through the coolant system (head gasket), and hissing out of the oil fill/valve cover means piston blowby. No oil/coolant mixing means that the head gasket should be sound, but never say never. Also check the plugs for wetness or oil fouling.
The 4-cyl isn't a bad engine to learn on, most top end work can be done with the engine in the car. Unlike the transverse 6-cyl where half the engine is butted up against the firewall and away from any line of sight.
A good repair manual is critical in reading up on what is involved as well as what tools and replacement parts you need to gather before you dive in. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-13-2009, 05:41 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
"A good repair manual is critical in reading up on what is involved as well as what tools and replacement parts you need to gather before you dive in. Hope this helps!
To follow up on what jdmccright said, there are Toyota factory repair manuals stickied at the top of this forum, that are available for free downloading. Download the generation 3 manual.
Mike
