Old 07-12-2009, 01:14 PM
Wyatts dad Wyatts dad is offline
corrosion on brake lines
2001 Cherokee sport in line-6, brake lines have fuzzy corrosion in various places and so do some other things, but not the body, what would you attribute this too?
Old 07-22-2009, 09:30 PM
shenriver_man shenriver_man is offline
Re: corrosion on brake lines
Its because of the way the lines are coated with a solution that kind of oxidizes. The best way i can explain it is its kind of like the way those old ten hole wheels on the older model fords oxidize after years of salt from the roads. Only this kind kinda looks like gritty mold.
Old 07-22-2009, 11:14 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Yep, it could be just dirt that has adhered due to oil/road gunk/moisture.
If you take a soft brush it should come off easily; then keep an eye on it and it will probably come back after a time.
If it's corrosion rather than road grime, then it will be tough to remove and you'll see parts of the brake lines that are eroded/rusted away.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
