Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-12-2009, 03:47 AM
blob754 blob754 is offline
boost problem
Alright, i have a 92 Plymouth Laser 2.0 turbo awd conversion fwd. I am getting a boost problem, my gauges (have 2 boost gauges) and they both say I'm getting 14lbs of boost on my stock turbo (don't even know how that is possible) but only sometimes will the boost actually speed up the car. sometimes it will accelerate like there is no turbo, and the gauge will read 14lbs of boost? where is all the boost going then, i looked at the hoses seemed to be fine. (no real cracks or anything... but im going to take a better look tomorrow underneath.) any ideas what it might be? my car seems to sputter when i start it and it idles, and when i drive in first gear it still sputters. and sometimes it sputters when the boost is engaging and pushing my car. Causing the turbo to cut in and out...even after it is warmed up still has the same problems... that about the full description i can give you on that.
Old 07-12-2009, 10:08 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: boost problem
Do a boost leak test. Sounds like air is getting out somewhere causing the car to run crappy
What mods are done to the car out of curiosity?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-12-2009, 04:16 PM
Re: boost problem
as far as mods none, i put a new k&n air filter on it. but I'm almost positive that there are no mods done to the car. i got the thing like 2 weeks ago only. haven't had a good chance to look at it yet.
Old 07-12-2009, 10:23 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: boost problem
Yea do a boost leak test.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 07-13-2009, 02:06 AM
Re: boost problem
Wasn't sure on how to do the boost test exactly, might still be a small one but not enough to worry about. but i found out that is was a bad spark plug giving me a lot of the problems. still idles like a hunker but i can expect that with the 17 year old engine it in lol. but all the accelerating problems have been fixed with it. Man the kid that owned my car before, needs to learn how to do things the write way. found out that the boost gauge was not installed right as well. Now consistent boost of 9 psi.
