Go Back   Automotive Forums Car Chat > Oldsmobile > Oldsmobile Classics
Old 07-10-2009, 08:28 PM
corkery12 corkery12 is offline
1970 cutlass supreme help
Hello all,
I bought a 1970 cutlass supreme a little more than a month ago. I LOVE this car but it doesn't have air conditioning, power steering and disk brakes. I just recently started educating myself about cars so I'm not knowledable, so ive come to ask for advice as to what brands and models of products I should get.
I have all four drum brakes but I only want the front two to be converted to disk. I'm willing to spend about $900-$1100 for the brakes so if you know someplace I can get all four drums converted to disks within that price range, I'm all ears. I have 15 inch rims if that helps with your decision.
Air conditioning: I am going to Arizona for college in about a year and I will need something to battle the heat. Pretty straight forward but I don't know where to start looking. I'm willing to spend about $1000 but less would be nice.
Power steering: of all of the things this is proving to be the most difficult to find what I need to get power steering and what brand is the best. I'm willing to spend $500-$1000.
Thank you for all your help you can offer
Old 07-11-2009, 05:59 AM
thisnametooktolong thisnametooktolong is offline
Re: 1970 cutlass supreme help
I would say that your best bet would be to dig around for a donar 442. They came with everything you are asking for. The breaks and master is a simple bolt in swap. The Dash and airbox would be included, and you would get all the brackets for everything. Down south they are still plentiful in the junk yard. The Cutless S also had disks on the rag top as an option. the brackets are the same for the 350 as well as the 455
Old 07-14-2009, 05:19 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Welcome to AF corkery12 !!
If you cant find used parts, yearone.com should have what youre looking for a little pricey but worth it IMO.
Good Hunting
1999 Grand Am SS 3.4 OHV
Old 07-15-2009, 09:59 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Just a couple of clarifications.......
A parts car would be helpful. But any 442, even a wreck will be priced way out of range. Disk brakes were an option on all models, even the base model.
I believe a front wheel disk brake set up from any A-body car, (Cutlass, Tempest/GTO, Skylark, Chevelle, all '68-72) will fit. You will need the master cylinder, front calipers, steering knuckles, rotors, hubs and wheel bearings.
Rear disk brakes would have to be an aftermarket set up. There are kits available, but they are a little expensive and imo unnecessary for normal driving.
Power steering....... its VERY unusual for these cars to have manual steering. In fact, I have never seen one. Are you sure your car is manual.... and not a PS car with the pump removed?
A power steering box from any A-body will fit. An olds engine PS brackets should be relatively easy to find. Also pretty much any power steering pump from the '70's will do, so long as you get the right pully. Imo get a new/rebuilt one, not a used one.
My dad bought a new 1970 Olds Cutlass back in the day. It had an aftermarket A/C system (installed new from the dealer), which was quite different from the factory A/C. The evaporator, control knobs and fan were in a chrome unit suspended below the dash, with the compressor and condensor in the usual place.
If you can locate one of these aftermarket AC units (they are available new as well as used) , the installation will be much easier than trying to convert your car to a factory-style AC set up.
Old 09-22-2009, 04:05 PM
carnuted carnuted is offline
To be perfectly honest, for the work and money you are talking about putting into the car, I would sell it and buy a car that has the options you want. Brakes and power steering aren't bad if you know what you are doing, but installing an AC system into a car without one will be very expensive, try upwards of $2000 by the time you get everything and replace the parts that are sure to be worn (I am doing it now on a 70), and it is extremely time consuming and will basically require everything from the seat forward to be taken apart. If your car is truly an all manual car, than it may be more valuable to someone looking for a racer than it would be as a driver. If you do go ahead and decide to do the work, buy a complete 4 wheel disc conversion kit. You can find them for about $1200, and having new, clean, and rust free parts to work with is definitely worth the extra couple hundred bucks. Power steering parts will be easy to find, but again, the AC stuff can easily be prohibitively expensive, so know that going into it. Good luck
