Old 07-10-2009, 03:19 PM
Bear Bear is offline
PCV Hose
Went to replace PCV Valve on my '96 3.3 liter and discovered that the hose that connects to the valve (the larger hose) was split. No problem, I will replace the hose and then I discovered it is a never ending hose that goes behind the plenum and runs forever. Does this beast terminate on the firewall side valve cover, it is not easy to trace even with a flashlight, Houston, we have a problem.
Old 07-14-2009, 12:04 PM
Re: PCV Hose/Update
Hose is on, the secret is to remove the coil pack (four screws) and then the hose can be pulled off of the valve cover and the new hose installed.
