Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 07-10-2009, 03:15 PM
pawnseven7 pawnseven7 is offline
Unhappy 1988 lincoln town car
car turns over refuses to start wait 2 minutes and then starts not all time has some blow by but when it runs its a dream machine help takes for ever to start sometimes
Old 07-11-2009, 08:45 PM
Kitt1993's Avatar
Kitt1993 Kitt1993 is offline
Re: 1988 lincoln town car
Sounds like the anti theft module is going bad. Is the anti theft light flashing when you crank it?
Nick names for my Car....
Abe Lincoln, opcorn:
The President,
Lucky Number 5
Old 07-12-2009, 12:57 PM
ante theft light not flashing ?
Old 07-12-2009, 02:54 PM
Towncar's Avatar
Towncar Towncar is offline
Originally Posted by pawnseven7 View Post
...has some blow by...
Just curious, what's this "has some blow by" in reference to ?
-Steven
1996 Town Car, Cartier
Old 07-12-2009, 06:37 PM
Kitt1993's Avatar
Oil Blow By. I would guess he is going through DPFE and Vacuum Solenoids. Might want to try the basics, Air, Fuel And Spark. Then get back to us.
The President,
Lucky Number 5
Old 07-13-2009, 02:09 AM
meaning of blow by is when oil is getting into air intake something like that
Old 07-13-2009, 02:13 AM
air fuel and spark are fine normal runs fine just takes forever to start and sometimes it fires right up its a real pain
Old 07-13-2009, 07:33 AM
Kitt1993's Avatar
yes. It clogs at the back of the intake.
The President,
Lucky Number 5
Old 07-22-2009, 10:33 AM
is there a way to fix this problem simple or major
Old 07-23-2009, 03:57 PM
could it be the vapour inlet port mybe plugged would cause the hard starting
Old 07-24-2009, 02:54 AM
on this 88 towncar has fuel has spark and doe,s run like a dream but refused to start today so turned over and over etc had a can of brake cleaner gave it a shot and it started right up its like id have to prime it first to make it start running out of ideas what,s causing the start problem d
Old 07-24-2009, 08:07 AM
Kitt1993's Avatar
Fuel pressure is low. I would check and replace the fuel pump.
The President,
Lucky Number 5
Old 07-27-2009, 01:21 PM
persay if the fuel pump has low pressure would,nt the car run bad because u step on it hard u tear some tread
Old 07-27-2009, 04:58 PM
Kitt1993's Avatar
Possibly, but I have seen fuel pumps do this. Just have someone put a gauge on it and check the pressure.
The President,
Lucky Number 5
Old 07-27-2009, 08:34 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Fuel filter could be clogged. It's an easy thing to replace, but no one ever pays attention to it. I would check that first.
Mike aka JYD
