Go Back   Automotive Forums Car Chat > Chrysler > PT Cruiser | PT Cruiser Convertible
Old 07-10-2009, 09:00 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
01 timing belt help.
I am replacing head gasket, Water Pump and Timing belt on an 01 PT Cruiser 2.4L manual tranny. Well I am having a hard time getting the motor mount bracket/plate off the engine, well mainly this one bolt, and I am sure the plate also, there is not enough room to get it out. Anyone know of any tricks to doing this.
Joe
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 07-10-2009, 11:19 PM
hundahunta hundahunta is offline
Re: 01 timing belt help.
you have to lift the front of the engine the side with the mount very high, the bolt comes out with the mount, also make sure you watch the ac pressure switch connector on the ac compressor, it gets tight sometimes when you lift the engine
Old 07-11-2009, 01:20 PM
I did this on a dodge neon (2.0L engine) before and had the same setup and I remember messing around to get the motor mount out but it was a pain and was just wondering if anyone knew of any tricks to make it alot easier.
Old 08-15-2009, 10:26 PM
Ok, well i got it all done and put back together. now, it won't start without having the gas floored and when idling it runs very very rough. I am pretty sure the timing is dead on tho, I checked it 3 times, after I got the belt on and tension on the belt-everything lined up perfectly.
Old 08-18-2009, 08:39 PM
Still not running, I am at a loss
Old 08-22-2012, 07:56 PM
Charlie Goode Charlie Goode is offline
Did you lap the valves while you had the head torn down
Old 08-22-2012, 08:00 PM
It's funny that you posted this because I'm having the same problem and I think the valves didn't seat so I'm tearing it all down again then I have another one to do right after this one oh how I love a pt lol I hate them ex specially that side mount
Old 02-17-2014, 07:29 PM
partyd partyd is offline
Are you getting any error codes ?
