Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 04-02-2003, 05:19 PM
runnscrd01 runnscrd01 is offline
Send a message via AIM to runnscrd01
98 sentra dash and park light problem
I have a 98 sentra and I noticed that the dash lights were out the other morning. Upon further inspection, the park lights and tail lights were also out. The head lights work fine. I looked through the fuses and all seem fine both under the dash and on the drivers side under the hood. None of the fuses are marked as dash, guage, park or tail lights. Does anyone have any suggestions or another location for the proper fuse? Or better yet is it a whole other problem? H E L P ! ! ! !
Old 04-02-2003, 05:21 PM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
and its a 98 that sucks, so all the fuses are fine... checked the wiring even tho i dont think that should be faulty on a 98 alrdy
you probally got a lemon from the factory
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Old 04-02-2003, 08:02 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
that sounds exactly like a fuse, try to find one that is labeled lights, or accessory, or something, and you could plug a wire in its place to see if it fixes the problem. If there are none labelled like that then you could just go through one by one until you find the bad one, I can almost guarantee it is a fuse
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 04-03-2003, 05:21 PM
Jetts's Avatar
wouldnt doubt it is a fuse but he said he went thru all the fuses alrdy
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Old 04-03-2003, 05:48 PM
sr20de4evr's Avatar
Well he said he looked through them, I took that to mean he visually inspected them to see if they were still working, if that's the case then one could have been burned out and he just missed it. If it isn't that my only other guess would be a shorted wire, maybe one got rubbed too much and shorted itself to the chassis, you could test this with a multimeter if the fuse theory doesn't work
'01 Black Sentra SE
'05 Silver WRX STi
Old 05-10-2003, 07:16 PM
chris007 chris007 is offline
same exact problem
Im having the same exact problem and it all started when the fuse for my cigarette lighter blew on me when hooking up my stereo system.
I replaced the fuse and still no change. I looked through all the fuses one by one and no other bad fuses. I already got pulled over once for it, plus with the dash lights out its kinda hard to see how fast your going (Oh Well)
If anyone has had this problem before please email me at [email protected]
