Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 07-10-2009, 08:18 AM
badbrakes badbrakes is offline
Cooling fan comes on as soon as ignition is on
Just had a problem with my 96 corolla (200 000 kms) and I thought I would post how I repaired the above - hopefully could be useful to someone else.
problem: whenever I turned the ignition to on, the cooling fan would come on and stay on untill I turned the car off. The car was behaving this way regardless of whether it was cold start or hot start.
In my case, the problem was the cooling fan switch (or some say sensor). It should test for continuity when engine cold. When the engine is hot, it should have no continuity. In my case, I had no continuity with the engine cold... so therefore the sensor 'tricked' the fan relay into thinking that the engine was too hot, hence the fan was always on.
Note that on this Corolla, there are two sensors (at least) for the cooling temperature. There's the cooling fan switch sensor and there's the sensor the sends the temperature to your temp gauge. That had me scratch my head a bit.... cause at first, I connected the car to an OBD2 and could see it was reading the temperature ok.... so I had initially ruled out the sensor... but a bit more research and I realized the fan has its own sensor.
Note that some posts point to Fan Relay - however I read that these are typically reliable.
How to fix it:
very easy.
the sensor is right underneath the distributor. Here's what I did:
1) empty about 2 litres of rad coolant into a clean container (you don't want coolant to leak when you take the sensor out.)
2) Unplug the sensor.
3) Pull the coolant overflow container out of the way. it's a slide in... just pull it up and out of the way.
4) use a 17mm deep socket, remove the old sensor, pop the new one right in.
5) reconnect sensor, put overflow container back on. Pour coolant liquid back in. make sure rad cap is on.
6) you're set. 30 minutes max.
here's a picture of what the cooling fan switch looks like.
Old 07-10-2009, 11:24 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Cooling fan comes on as soon as ignition is on
Thanks Badbrakes. I'll add a tidbit to say that sometimes these fan temperature switches will fail the other way where they will prevent the fans from coming on at all. You can bypass the switch by unplugging the connector before turning the ignition on so that the circuit is open, causing the fans to run until you can get home or to a repair shop. Thanks again!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-10-2009, 12:20 PM
Excellent point JDMCCRIGHT. This was all new to me - but part of my periodic 6000 kms maintenance will now include testing whether the fan works nicely... 30 second test... as you say unplug the cooling switch, turn the ignition on --- if fan doesn't come on - something's wrong.
Old 06-16-2014, 11:44 AM
harris24742 harris24742 is offline
someone please help me regarding a corolla 2004 (asia)
I got my ac condenser replaced. For this, the radiator was disassembled and then reassembled.
Now when I switch the car on ignition position, the coolant fan turn on too even if the car's dead cold.... it has never happened before.
sometimes it doesnt turn own on ignition and would only turn on upon proper temp or when ac is switched on.. as in whatever is normal...
I'd like to know if it has to do with the connector installed at the front grill near the condenser and what happens if I reverse it and then reconnect... as in would this cause any damage? I dont think its direction specific.. no arrow is there + its symmetric.. so it shouldnt make a difference
Old 06-16-2014, 01:54 PM
jdmccright's Avatar
The RustBuster
It is just a thermal switch, so it would not matter which way the connector was plugged into it if the design allows it. The fan coming on means there is a break in that circuit somewhere or the switch itself is bad.
To check if the break is not in the switch, unplug the connector, use a piece of wire to short the two terminals in the connector, then turn the ignition to 'On'. If the fan stays off, then the switch is bad. If it turns on, the break is elsewhere in the circuit.
Welcome to AF...I hope this helps you!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 06-16-2014, 03:04 PM
From what you are describing, it seems that the switch as I outlined in the post may be the problem. It's been a few years but if I can remember, that switch was around 20 $ cad and rather easy to replace.
Old 06-18-2014, 12:06 PM
badbreaks.. please follow me on twitter @harrisalich
through DM please help me sort out this issue. and sure, You can unfollow me later :P
