Old 07-09-2009, 11:23 PM
MrAnon MrAnon is offline
K2500 5.7L no codes misfire
98' K2500 5.7L:
Intermittent misfire
Started out with an engine light-P0339A-Intermittent Crank position sensor malfunction(replaced twice).
Still has an erratic misfire.
The only weird thing I noticed(by use of a scan tool) the RPMs will spike at 7500 RPMs(at idle). Should I be looking at a camshaft position sensor problem? Distributor problem?
Any help or information would be appreciated. Thanks.
Old 07-10-2009, 06:26 AM
Jeremy-WI Jeremy-WI is offline
Re: K2500 5.7L no codes misfire
The rpm spike on the scantool would suggest it is still a problem with the crankshaft position sensor or its wiring. The VCM uses the crankshaft sensor for rpm readings because it gives a signal 4x per revolution versus the 1x per 2 crankshaft revolutions it would see with the camshaft position sensor signal
Check the crankshaft position sensor connector for loose pins and double check engine grounding points
Old 07-10-2009, 01:21 PM
jonnik jonnik is offline
If I'm not mistaken, the engine computer governs the max RPM's in park to prevent damage.
