Old 07-09-2009, 08:56 PM
sunmicroman sunmicroman is offline
Weird Problem (transmission)
I noticed today when I was checking the transmission fluid level that I could not put the gear selector arm into first gear at a stop (1). I can put it into drive and even second (2) fine but it just won't let me put it into first.
The weird thing is the transmission works fine and when in drive first works great. In fact, I would have never even noticed the problem if I hadn't tried to manually shift into first as I would normally never do that. Is this normal? If not, what could be the problem as the transmission seems to work fine in drive (first gear and all)?
Old 07-09-2009, 09:29 PM
wiswind wiswind is offline
Re: Weird Problem (transmission)
I wonder if the Transmission Range Sensor, aka Neutral Safety Switch is rusted....preventing you from shifting into 1st?
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 07-09-2009, 09:45 PM
Wouldn't that prevent me from shifting into any of the other gears too?
If that is the case, how hard is it to replace?
Old 07-10-2009, 06:18 AM
northern piper's Avatar
northern piper northern piper is offline
It's not hard to replace but the old one likely will be destroyed in its removal. I have heard other complain of binding on the shifter cable. I'd also check all cable attachment points as sometimes the screws will come loose. Beneath the dash as well the shifter bracket at the steering column can become loose leading to difficult shifting. Does the shift selector pointer indicate the gears properly?
P
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
Old 07-10-2009, 12:02 PM
P
Thanks for the reply. Yes, the shift selector does indicate the gears properly which is what is confusing me. The only gear it won't let me move the selector into is "1", but the others show correctly when shifted to.
Old 08-04-2009, 10:19 PM
mapmas mapmas is offline
I have a 2000 ford windstar sports (90,000 miles). I was at a red light and when preceded to go, the car stalled. It wouldn't go forward in drive, 2nd or 1st. It will go in reverse. Do you think a 1995 transmission will go in it?
Old 08-05-2009, 11:21 AM
tomj76 tomj76 is offline
Have you taken it to a transmission shop for a diagnosis and estimate? If needed, a rebuild will cost under $2000 with good warrenty.
Old 08-08-2009, 06:39 AM
searcherrr searcherrr is offline
Send a message via AIM to searcherrr Send a message via MSN to searcherrr Send a message via Yahoo to searcherrr
Maybe some wiring under the hood is blocking the lever/switch when you shift the gear selector stick. I haven't ever looked for it on my Windstar, but on my other car if something were to get in the way of this lever/switch (which is pulled by a cable) it would interfere with gear selection.
Though the TRS could very well be in need of replacement too.
1995 3.0L 3000GT NA FWD ATX - ProwlerGT on 3si.org
1995 3.8L Ford Windstar GL
"I drive the newest 1995 Ford Windstar anywhere..... when its not broken."
Old 05-29-2012, 02:18 PM
conrusco conrusco is offline
I would check to see if you have a broken shift tube
