Go Back   Automotive Forums Car Chat > Pontiac > Sunbird/J2000/2000 Sunbird
Old 07-09-2009, 12:42 PM
Paul94Z28 Paul94Z28 is offline
84 Sunbird Front Swaybar Removal
ok, the manual makes this look pretty easy...
Car on jackstands, remove end links (including 24 year old original that takes 3 hours and a torch). Loosen and remove front sway bar to body bolts and slide bar out driver side after removing wheel.
There is no way that will work as I described it. There is not enough room once you remove the sway bar-body nuts for the U bolts to come free from around the bushings.
Any ideas here? This has to have been discussed before. I want to get the bar refinished and put some nice energy sustension bushings on there.
Advice Appreciated.
Old 07-24-2010, 10:24 PM
Re: 84 Sunbird Front Swaybar Removal
Got this done, not bad...
Tags
bar , sunbird , sway
