Old 04-02-2003, 04:21 PM
beario beario is offline
b18c..into crx vtec 90 is it possible and easy
has any one done this,and wot was the results 1/4 mile time???will the later b18 bolt to the earlier cable gearbox,and does it use the same motor mounts....i am based in london england...as tech as possible please guys,thanks
v-tech...the only way to go...
Old 04-02-2003, 04:25 PM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
need new mounts, wiring, axels, tranny
possible yes
easy kinda
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Old 04-02-2003, 05:07 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
if the CRX you have is a VTEC one already (england did offer that, so no flaming from USDM people), then all you need is the motor, including distributor, the ECU, and a conversion harness to go from OBD0 to OBD1 or 2 (depending on the year b18c you get).
its a lot easier for you, since yours has a b16 in it already. but i would just get a b18c block and put your b16 head on it and be happy with that. no ecu, distributor, or harness swapping.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 04-03-2003, 05:53 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Hey Beario , u got any pics of yer car m8
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
crx vtec bonnet and lights plus cat Q sixth020010 '88 - '91 Civic | CRX | Wagon | Shuttlee 11 11-09-2005 04:58 PM
B18C into civic or crx JD18 JDM Motor & Parts info/chat 0 05-28-2005 07:59 PM
b18C into a 91 crx GENONCARL '88 - '91 Civic | CRX | Wagon | Shuttlee 7 05-13-2003 07:29 AM
HELP!!! 99' b18c into a crx please help ef8gen4 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 03-13-2003 09:58 AM
b18c into a crx spy54 Engineering/ Technical 3 03-07-2002 01:59 AM
