Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 07-08-2009, 08:05 PM
super_man_736 super_man_736 is offline
engine for 1996 2.2 cavalier
I have a 1996 2.2 cavalier i want to swap out the 2.2 motor for something with a little more power what would drop in with using the stock wiring harness and etc..
Old 07-09-2009, 03:36 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: engine for 1996 2.2 cavalier
There's no such engine.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 07-15-2009, 07:24 PM
what would be the best engine for my 1996 do u think
Old 07-27-2009, 04:37 PM
J-Ri's Avatar
The 2.4 Quad-4 has about 35 more HP and requires "minimal" modifications.
The Ecotec has about 30 more HP (but due to it's lighter aluminum block, makes for a quicker car) and requires an entire donor car to pull the engine, trans, PCM, BCM(?), and entire wiring harness to make everything work. Probably better to sell your car and buy one with an Ecotec in it already.
Of the two, I would say Ecotec just because of how much better the car handles without the heavy cast iron block of the Quad-4. There are also more performance things available for the Ecotec, if that matters to you.
