Old 07-08-2009, 05:05 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re-promoting Adhesion On Double Sided Tape & Painted Metal
I just got the GTC back from the body shop about two weeks ago. There is a long molding that runs along the door. It's starting to pull off on the ends on both sides. Now, the moldings can't be removed as that would ruin them, they are made of polyurethane. They are held on with double sided tape and I was wondering if there was anything safe for painted surfaces that I could apply that would get the tape to adhere.
Clint
Old 07-08-2009, 09:06 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Re-promoting Adhesion On Double Sided Tape & Painted Metal
In the past, I have used this silicone-type adhesive (in a tube) that is intended to secure automotive trim moldings to painted surfaces. I think Loctite make it.
Old 07-08-2009, 10:12 PM
Polygon's Avatar
The Red Baron
I found this, sounds similar.
http://www.shop3m.com/70071349412.html
Did you just apply it to the tape and then stick it back down, or did you remove the tape?
Old 07-09-2009, 09:49 AM
MagicRat's Avatar
I think either way would stick just fine.
But I think just adding the adhesive would increase the thickness of the moldings, just in that area, and make a bit of a wave, or bump.
Removing some tape would be ideal, so long as you do not damage the existing bond or the trim.
