Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 07-08-2009, 12:42 PM
ted2134 ted2134 is offline
Exclamation 94 cadillac deville starts then shuts off!
Hi my 94 Cadillac deville will start then run for about 10 min then it will shut off and will not start for like a day. when it was running the radiator did not get hot at all. if you try to start it it will just turn over no spark. Please help!
Old 07-08-2009, 04:04 PM
maxwedge maxwedge is offline
A990 racer
Re: 94 cadillac deville starts then shuts off!
Crank sensor, ign module, these things most be checked with a shop manual or scanner will check for cranking rpms, no easy answer here.
Old 07-09-2009, 07:03 PM
cadi509 cadi509 is offline
if your not getting spark sounds like the distributor but if thats not it maybe your alternator isnt putting out the power to the spark the plugs and your just running the battery dead, and it could also be the ignition switch also check all your main fuses and maybe replace a few theres spares right on the fuse block. all and all sounds like electrical
