Old 07-07-2009, 09:38 PM
schadd1971 schadd1971 is offline
abs/brake light on 2002 windstar...whats it all about?
Ive had a 2001 and now a 2002 windstar and that stupid abs/brake light is driving me crazy.....what up with this...and whats the fix?
Old 07-07-2009, 09:46 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: abs/brake light on 2002 windstar...whats it all about?
This is not very important. It's just for telling you that the abs circuit doesn't work, because it has encounter a problem. So if you brake on an ice surface, you will slip, that's it. You'll not crash.
Many things can cause the ABS circuit to fail, intermitently or not:
Bad contact
bad ABS speed sensor
bad ABS servo...
If it make you nervous, you can either repair it, or remove the bulb.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 07-07-2009, 09:49 PM
MARZBX157's Avatar
MARZBX157 MARZBX157 is offline
Here read this, it explains everything pertaining to the ABS problem.
2000 Windstar 3.8 V6
Old 07-07-2009, 10:30 PM
bdahl385's Avatar
bdahl385 bdahl385 is offline
I think you might have overlooked the link:
http://www.fordwindstarrecall.info/
2000 Windstar SE 3.8L 125k miles (mine)
2006 Hyundai Sonata LX 3.3L 108k miles (wife's)
2013 Hyundai Elantra GLS 21k miles (daughter)
Old 07-07-2009, 10:50 PM
MARZBX157's Avatar
oops, sorry.
Old 07-07-2009, 11:47 PM
wiswind wiswind is offline
We have a sticky post about the brake pressure switch.
This is a easy to replace part....and the part is not expensive.
I recommend that you check to see if the switch looks damp from possible leaking brake fluid.
It is normal for the level of the brake fluid in the master cylinder to drop slightly as the brake pads wear.
The fluid level sensor is set to light up the Brake and ABS lights (may depend on year) when the fluid level is just slightly below the "FULL" line.
So.....try the cheap and easy first......fluid level......verify pressure switch.
Other causes can be determined by having the ABS code(s) read.
A common cause of the ABS light is a issue with one of the wheel sensors.....they can get bumped....and be slightly too far from the exciter ring (the gear like ring with the teeth).
This problem is easy to correct.....adjust the sensor so that it is close to (but not touching) the teeth of the exciter ring.
Also double check the wire that goes the the wheel sensor.....making sure that it is intact (has not been caught and torn from its mountings or otherwise damaged).
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
