Go Back   Automotive Forums Car Chat > Ford > Tempo | Topaz
Old 07-07-2009, 09:31 PM
spenser spenser is offline
Exclamation power brake problem
The power resevoir is full. Start the car the fluid goes way down. As u steer it becomes stiffer added fluid still stiff. Then when u shut if off fluid gets foamy and over flows!
Anybody have a solution?
Old 07-11-2009, 06:44 PM
rhandwor rhandwor is offline
Re: power brake problem
I think you are not getting circulation through the power steering pump. Look for crimped hoses or damaged metal tubing. With the car on jack stands move the steering wheel back and forth and see if this helps. Is this a new pump you installed or an old pump?
