Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 07-07-2009, 02:54 PM
garcam123 garcam123 is offline
87 G20 Power Windows quit working..Help Please
My power windos just quit working. The power door lock still work and I think they are on the same 30 amp fuse/breaker.
I took the door panel off and tested the pink wire and it shows no current.
I have good current at the fuse so it has to be somewhere between the fuse and the wire at the switch.
I can't find the wire in the harness after it goes into the underhood area through the door. Can someone please tell me where to look.
Thanks,
Gary
Old 07-25-2009, 06:27 PM
Schrade Schrade is offline
Re: 87 G20 Power Windows quit working..Help Please
If both windows quit, you can rule out a short in the line to either one window.
You're gonna' need a wiring diagram to find out the point that the source voltage splits.
Good job checkin' the fuse; but without the diagram, you're gonna' have to follow the line to the split-off splice...
Tags
electrical , g-20 , power , van , windows
