Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '01-'05 Civic
Old 07-06-2009, 10:30 PM
big tex84's Avatar
big tex84 big tex84 is offline
03 ex overheating issues
ok im trying to find this out for a friend, he has a 03 civic ex with around 100K on it, it has started to overheat at random, it happens usually after he passes someone or turns on the a/c, he has taken it to 2 different dealerships, they cant find anything wrong with it they ran dye through the cooling system, fans work properly and everything, cant find a clog or leak. when it happens the temp gauge goes up and it spews coolant from the overflow onto the engine. they cant figure it out, has anyone else had this issue?
Finally getting my swap done, Thought I would be relieved and satisfied, now I just wanna spend money on other car parts, WHERE DOES THE MADNESS END!!!!
Old 09-17-2009, 06:58 PM
bulleyes00 bulleyes00 is offline
Re: 03 ex overheating issues
I have the same problem. If you find out what wrong , please let me know.
Old 09-17-2009, 08:40 PM
rhandwor rhandwor is offline
I would look for a partially plugged radiator.
Old 09-30-2009, 11:06 PM
pcar993 pcar993 is offline
I just started having this problem. In fact, it's why I joined this forum...
I have 2003 Civic Ex with 110k on the clock. I too have been having random overheating issues. My wrench has replaced the thermostat, but that wasn't it. Currently he's doing the timing belt and water pump (it's time anyway) but the water pump impeller seems fine. He's going to drive home for the next couple of days and see if he can get it to happen to him. Right now he's really stumped.
I did notice during the last episode that the heater stopped blowing hot air when it happened. So it seems that cicuolation is not happening. Any thoughs would be appreciated.
Chris
Old 10-01-2009, 01:18 PM
I would disconnect both heater hoses and flush the heater core. Check that both the top and bottom hoses are hot and appx. the same temperature. When it reaches operating temperature.
Then make sure the fans come on.
