Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 07-06-2009, 02:37 PM
julie21078 julie21078 is offline
Question 1997 4runner power steering lines
hi all! We just got a 1997 4runner and there is a power steering line leaking. we are having a real time getting the line off. even got a 17mm line wrench and it still doesnt want to come loose. Seems to be the return hose that is leaking. Anyone have any good ideas for getting these lines off??
Old 07-07-2009, 12:04 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: 1997 4runner power steering lines
If it's because you can't get the wrench in there properly, a 17mm crowsfoot flare wrench on a ratchet may work.
If you get get the wrench on but the nut is too tight, hook a 2nd box wrench on as an extension for more leverage.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 07-12-2009, 12:51 PM
Question Re: 1997 4runner power steering lines
Thanks. GOt them off. But now we can't find a new return hose. I did find the pressure hose and it is on it's way. But can't find the return hose. I have searched and searched on the web with no luck. Anyone know where we might find one????
Thanks!
Old 07-14-2009, 08:45 PM
fourwd1's Avatar
AF -Advisor
Isn't your return line just normal hose held on by hose clamps? If so just replace the hose.
89 4Runner - stock
