Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 07-06-2009, 02:26 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
81 G20 Carburetor problem(?)
My girlfriends dad has a 1981 Chevy G20 5.0L. He took a short trip over the weekend and on his way back it started running bad (wanted to stall, etc.) and had trouble getting it started - I think that was a battery problem but I will get more details later. Anyways when he got home he removed the doghouse and he said when it was idling the carburetor was filling up with gas. I am a mechanic but honestly I don't know much about carburetors.
Any suggestions, ideas, etc...
Thanks Joe
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 07-07-2009, 09:03 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 81 G20 Carburetor problem(?)
Thanks Joe
Sounds like needle and seat or float is letting it flood over.
Needs another carb or the old one rebuilt.
MT
Old 07-07-2009, 04:48 PM
how hard are they to rebuild?
Old 07-07-2009, 05:05 PM
MT-2500's Avatar
AF - Advisor
About 3-4 hrs for a good rebuild.
But you need to make sure it is rebuildable.
Some are plain worn out and leak gas threw inside.
MT
Old 07-10-2009, 03:35 AM
manicmechanix manicmechanix is offline
I assume this has the original Quadrajet. Maybe you could carefully unbolt the top and clean out/replace and adjust the float and needle and seat assembly and replace the gasket. Sometimes the casting on an old Quadra can leak, but it might just be a bad or dirty float needle and seat or gasket.
Old 07-25-2009, 06:37 PM
Schrade Schrade is offline
Float leaking, filling the intake with fuel. Is it burning black exhaust??? Carefully remove the carb, the top of the carb body, to NOT spill fuel out of the bowl, and check the float.
Vacuum leak will also cause flooding. Any loping idle?
Old 07-30-2009, 08:48 PM
wafrederick wafrederick is offline
Banned
The Quadrajet is very easy to rebuild and parts are much easy to get.Muscle Car,a tv show on Spike TV did an episode how to rebuild these carbs.
