Old 07-06-2009, 01:28 PM
davdogg42 davdogg42 is offline
gas cap code PO 442 97 Lesabre
check engine light came on 2 weeks ago
I replaced gas cap when it came on, light still on.
but here is a problem with my gas cap, my gas door is pretty much rotted/rusted out, which caused the metal tube that receives the gas pump to rust out.
im thinking there is little chance of maintaining a proper seal like this.
Any other thoughts?
Thanks
Old 07-06-2009, 06:30 PM
Hapynzap Hapynzap is offline
Re: gas cap code PO 442 97 Lesabre
Evap solenoid valve
1999 LeSabre Limited - 154k
2002 LeSabre Custom - 145k
1985 Century Limited - 252k
Old 07-06-2009, 08:23 PM
maxwedge maxwedge is offline
A990 racer
If you have any holes in the tank filler tube you will get an evap code, fix that first.
Old 07-08-2009, 11:53 AM
Robdaparamedic Robdaparamedic is offline
Holy Rocket Science BATMAN POW WHAM ! LOL
Old 07-08-2009, 12:57 PM
Ok that looks like my least expensive option right now, it is pretty rusted out.
I will look in the junkyards for a better one
I will post results thanks
Old 07-08-2009, 04:01 PM
happydog500 happydog500 is offline
Remember, when you get a code, fix the problem, sometimes you have to clear the code for it to go away.
After you fix it, clear the code.
Chris.
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
Old 07-10-2009, 01:23 PM
Chris.
Replaced gas cap, cleared code.
CEL was off for 1 hr then came back on
auto zone coded 442 again.
Going to have smoke test done to identify the source of the leak
I bet it is the gas neck tube, it is very rusted at the top and the gas cap doesnt get a good seal.
But im going to shell out the money for the smoke test before I buy any parts.
BTW, you can get some good gas neck tubes from down south for about 75 buck plus shipping I found out online
Old 09-26-2009, 09:52 AM
army army is offline
hi davdogg 42 did you ever find the problem with that 442 code ?
Old 10-02-2009, 03:28 PM
hi davdogg 42 i found the problem to my 442 code it was the sending unit above gas tank, the evap line on the sending unit rusted out i patched it up got e tested and past now i will look to get tank and sending unit expensive proposition.you can see the unit 3 lines made of steel with ruber lines connected to them you need to take rear assenger side tire of.
