Old 07-06-2009, 12:37 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Master Cylnder line location
I am working on a 95 Chevy Lumina NON-ABS. The guy replaced all of his brake lines from the Master Cylinder back and now the Right Rear Wheel locks up when you hit the brakes hard. He thinks he may have a line in the wrong location, which I believe is what happened. But I need to know which line, from the master cylinder, goes where?
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 07-06-2009, 01:29 PM
maxwedge maxwedge is offline
A990 racer
Re: Master Cylnder line location
From the m/c they go to a proportioning valve then to the rear, no?
Old 07-06-2009, 02:25 PM
Well there no proportioning valve around the master cylinder like most but I didn't look under the car, I can see all 4 lines go straigh down when they come out of the MC, and then the rear 2 go under the car. There is only 1 line that has an adapter on it at the master cylinder.
Old 07-06-2009, 04:12 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
I would wonder if he has a lotta air in the opposite line, which will affect the diagonal front brake as well. With only one front and one rear supplying good braking, it's gonna lock and drag the working rear when the vehicle nose dives and gets light in the ass end...
Try proper split diagonal bleeding procedure if not done already.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 07-06-2009, 07:05 PM
I thought of that as well, but the pedal feels great.
Old 07-06-2009, 08:29 PM
A990 racer
Red face Re: Master Cylnder line location
All disc brake cars/trucks have proportioning valves, on the 95 they are built into the m/c I though it was seperate.
