Old 07-06-2009, 09:05 AM
The Yes Man's Avatar
The Yes Man The Yes Man is offline
Crazy Modeler Brakes
Hi
I am having a bit of trouble with the Crazy Modeler brake discs for the Tamiya FXX.
I have made one of the discs using the PE pieces but am at a loss with what to do with the calipers. I need to cut a shape into them to allow the disc to fit but i am not sure how. Its not like i can just use a saw or a knife as they need to cave in rather than be straight
Any tips/suggestions gratefully recieved
Old 07-06-2009, 10:04 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Crazy Modeler Brakes
Yeah, that's a difficult one. There is no simple, easy way to use the calipers on the kit parts without tedious, maddening surgery on each caliper. You're not missing any tricks, and Crazy Modeler did not provide an obvious solution to this problem. If you manage each caliper in 1 hour and can still use your hands afterward, you have more skills than I do....
PHOTOBUCKET SUCKS
Old 07-06-2009, 10:13 AM
jano11 jano11 is offline
Originally Posted by The Yes Man View Post
Hi
The only easier way to do that is to use your dremel with an abrasive disc that is roughly the size of the PE brake discs.
I know that the Dremel abrasive discs are bigger but you can get wear them down to the right size easily by using them on some hardened steel piece or even better one a hard stone.
Hope it helps.
Old 07-06-2009, 10:29 AM
Thanks, ill have a go. If you have trouble understanding the reply it means that it didnt go too well and i am having problems typing with only a couple of fingers
Hope it helps.
Thanks, i have a crappy cheap version of a dremel somewhere that i never use so i will try and dig that out later. It was last seen a couple of years ago though so i hope i have not thrown it out.
Old 07-06-2009, 06:24 PM
cyberkid's Avatar
cyberkid cyberkid is offline
CM has also made pe cutting disks meant for dremels, click me to see.
The smallest and middle disks should be about the right size.
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 07-06-2009, 07:36 PM
da_ashman's Avatar
I had a similar problem with my Challenge Stradale, using the Acutsion Enzo photoetched discs. I traced the disc outline onto some 1mm styrene and then cut out the middles. I then carefully cut the kit brakes in half and glued each side of the caliper to the styrene, so that the cutout (disc) is where the photoetched disc would sit. and then carefullly filed away the excess, it is a tedious task and took me ages, with this method if you were carefull you could get the disc to spin. Its a hard thing to explain in text. Good luck
Old 07-07-2009, 05:48 AM
Great, ive added those to the cart for my next order. I did find my 'dremel style' tool and it has nothing like that so even if i dont use them on this they will be handy for the future.
I have some spare calipers so might give this a try too. I was thinking about something along these lines before i started the thread so i think i can understand what you mean. I dont suppose you covered it in the WIP did you, or if there is any tutorial anywhere?
Thanks for the help guys I will start a WIP on here for it as it is my first time not building OOB and i have lots of questions.
Old 07-07-2009, 09:06 AM
bozothenutter bozothenutter is offline
get these in a few sizes/thicknesses
http://www.dremeleurope.com/dremeloc...83&prod_id=103
don't have to be dremel.
I use the to hollow out calipers all the time
