Old 07-04-2009, 01:40 PM
erich1920 erich1920 is offline
96 cavy wont start
i have 96 cavy 2.4 that wont start changed the pcm out but same thing. did a volts test on it no power to trottle boby but have it every where eles also hooked it up to scanner nothing happend said check connection
Old 07-04-2009, 06:22 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 96 cavy wont start
What doesn't have power at the throttle body? There's a TPS and IAC. Get a wiring diagram and check for power at the PCM. If you have it at the PCM and not at the TPS or IAC, you've got an open wire somewhere
For the "check connection", check the cigarette lighter fuse, the DLC gets power from it. If it's blown you can't communicate with the PCM.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 07-05-2009, 10:28 AM
thanks 4 time sir there is no power to none of that or cam shaft or crank shaft
Old 07-05-2009, 10:49 AM
Originally Posted by erich1920 View Post
thanks for your time sir there is no power to none of that or cam shaft or crank shaft or map. im going try what u said but any help is better then none. this is a very nice car that i bought but that why i got it so cheap i gave 300 dollars but didnt think that it would be hard to get going
:loser::loser:
