Old 07-03-2009, 01:18 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Rear axle/bearing clearance
In the next few days I'm going to be changing the diff fluid in my 92 K2500 EC/SB (non-HD - so 6 bolt rims and small 14 bolt diff and not a posi). When I do that I'm also going to have a close look at the axle seals and replace them if they look old or are leaking. My truck has about 250k miles on the clock. The body is pretty good with only a little rust near the front of the wheel openings of the fenders. Mechanically the truck is excellent, and in order to maintain this condition I want to check the rear axle/axle bearing clearance. Can anyone let me know what we should be looking at for acceptable clearance? Thanks.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 07-04-2009, 09:43 AM
j cAT j cAT is offline
Re: Rear axle/bearing clearance
If this is the original bearings I would pull the axles and inspect for damage at the bearing area,,,then install new seals/bearings...
there are certain spec's but if its working fine why ????
with proper diff fluid replacement [drop cover and clean every 30,000mi]this diff will outlast the rest of the vehicle...
Old 07-04-2009, 07:18 PM
maxwedge maxwedge is offline
A990 racer
FYI axle shaft end play .010-015".
Old 07-05-2009, 06:21 AM
Thank you for the info.
