Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-01-2009, 08:57 AM
jima4624pY2 jima4624pY2 is offline
Talking fuel problem
I have a 94 cutlass cruiser with 79000 miles on it and it won't start.It acts like a fuel problem when i put a gauge on it shows 0 with key on but when i put 12v to the fuel test lead i get 47lbs and i change the relay and check the fuse all good gave it a little shot of starting fluid and it started and i tryed to start it with the fuel test lead connected but it still won't run and help would be great thanks.
Old 07-01-2009, 09:34 AM
maxwedge maxwedge is offline
A990 racer
Re: fuel problem
It tests good at the fuel test lead but will not run with 47 psi? Do you have injector pulse? BTW, what engine?
Old 07-01-2009, 04:40 PM
Talking Re: fuel problem
i do not know if i have injector pulse how do you check that it has no preasure with the key on or if i crank it only if i use the fuel test lead is there something eles i could check and the motor is a 3.1 thanks
Old 07-01-2009, 07:29 PM
A990 racer
Re: fuel problem
Go to autozone.com, repair guides, for a circuit diagram for the fp.
