Go Back   Automotive Forums Car Chat > Opel/Vauxhall > General Discussion
Old 06-30-2009, 01:49 PM
fitzie01 fitzie01 is offline
battery going dead??
I have a 2.2 auto convertible astra 52 plate with a dead battery. this is the fifth or sixth time it has happened despite a new 075 battery (different voltage and size but i am told it is the correct 1?). i suspect the alternator?? any ideas? does anyone know where to find a cheap alternator.
Old 09-19-2009, 02:36 AM
sparkeykev sparkeykev is offline
Send a message via Skype™ to sparkeykev
Re: battery going dead??
You can get one at a car wreckers
perhaps an auto electrician can repair it for you
Old 01-29-2010, 03:51 PM
jd_975 jd_975 is offline
Hi mate, is the battery going flat whilst you are using the car or while the car is laid up? If it is going flat while you are driving i.e. the car breaks down so to speak then you are most probably looking at an alternator fault, basically it`s putting little or no charge into the battery so when you demand more from the electrical system like in the current weather needing headlights and heated rear screen on constantly the battery simply drains, once it gets below 11 volts the engine ecu cant function anymore so the car stops. If it`s a case of the battery drains over night then you more likely have a current drain, you need to get the car checked by an auto electrician to see what the current drain is at rest, it should be as close to zero as possible, most vauxhall`s draw approx 0.07 amps once all the systems have powered down, the most common cause of current drains is after market head units, the ignition and battery lives are the wrong way round on vauxhall wiring even though the plugs are identical to standard iso plugs, this has the effect of leaving the head unit on standby when the car is switched off and can drain a battery over night. Most of your local breakers should have an alternator for a Z22SE they are notorious for cam chain failure!
Old 01-09-2012, 06:55 PM
fhqiihcy fhqiihcy is offline
go to 4s shop buy new a battery!
