Old 06-30-2009, 12:54 AM
3000-GTO's Avatar
3000-GTO 3000-GTO is offline
Radiator fan not working
My radiator fan is not turning on. I tested the motor and it works, I tried replacing the resistor which didn't make a difference. I swapped out the condenser fan relay (which is working) for my radiator fan relay, this made no difference. I should mention I was using a data logger to test the fans so I think that pretty much rules out the temp sensor being the culprit. However, when I run the test I can hear the relay for the fan click on, and then once the test finishes it clicks off.
If anyone has any ideas please help. The only thing that I can think of is the wiring harness to the fan being corroded at some point after the relay. Thanks for the help.
1995 VR-4: 15G turbos, front mount intercooler, 3sx high capacity radiator, MBC, custom catback, retrofitted HIDs
Old 06-30-2009, 11:55 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Radiator fan not working
Test for continuity to see if power is getting thru the plug in. It is plugged in isnt it?
Old 06-30-2009, 07:45 PM
3000-GTO's Avatar
It is plugged in. I will try testing to see if I'm getting any current.
Old 07-05-2009, 01:39 AM
vectorspecialist vectorspecialist is offline
if you get low current check for resistance, you might have a broken wire somewhere...which would suck to track down
yup, here i am
