1998 century air problem
1998 buick century--always blows hot no matter how low the temperature is set--ac or vent makes no difference--as if inside cabin temperature sensor is broken/giving bad data
Re: 1998 century air problem
Is the compressor running and if so, have you checked the low & high side pressure?
Knowledge can be communicated, but not wisdom! ![]() ![]() |
haven't checked compressor---blows hot even in 'vent' mode which should bypass compressor and use outside air only
SOunds like the trap door isn't shuting to or opening to control from where the air flows ( heater core ,,, or AC evaporator )
