Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 06-29-2009, 10:05 AM
mr_terrilln mr_terrilln is offline
Send a message via Yahoo to mr_terrilln
Angry RPM's Increasing
I have a 1995 Oldsmobile Aurora. Whenever my car get to the speed of 40 the service engine light comes on and the rpm's increase however my car will not pick up speed. What is the problem ?
Old 06-29-2009, 11:51 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: RPM's Increasing
Is it shifting gears?
Does it have a lack of power?
Do you know what codes are causing the check engine light?
Old 06-29-2009, 12:10 PM
It shifts gears until it get to 40 mph. Once at 40, the rpms jumps and stay up however, the car will not shift gears anymore. After it do this I turn the car off and crank it back up and it is once again fine until it gets to 40 again and does the same thing over.
No, it do not lack power. You can still hear the motor rising but will not increase in speed.
No
Old 06-29-2009, 01:19 PM
Airjer_'s Avatar
Sounds like you may be having some transmission issues. Make sure the fluid is full and not burnt smelling. If the fluid is good it would be a good idea to find out what trouble codes are present. This can help narrow down the potential possibilities that are causing your symptom.
