Old 06-28-2009, 08:25 PM
VEfreak VEfreak is offline
Intake manifold problems
Hey dudes, I'm dropping a used engine into my 2001 because the original 3400 V6 overheated. When torquing down the upper intake on the new engine, the flange closest to the belt tensioner broke cracked badly. I pulled the upper intake off the engine and the gasket under the flange was crushed paper thin. It was a fel pro gasket that had been purchased at reibes. Is this a common problem with these manifolds or gaskets? I'm apprehensive to go get one from pick and pull and then have it break on this gasket. Would ib be strong if I had it welded and machinced?
Old 07-01-2009, 09:29 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Intake manifold problems
yeah sounds like you over torqued the bolts. Its pretty easy to do.
A good machine shop should be able to weld it and mill it back down. If not any upper/LI from a 99-05 3.4 should work.
Here are the updated torq specs..as of 2003.
3400 V6 SFI LIM Gasket Procedure
1999 Grand Am SS 3.4 OHV
Old 07-01-2009, 02:49 PM
3100 3100 is offline
Banned
junk jard intake manifolds are $25 what I do is take LIM and UIM bolt them together and bring them like that to the register and get them both for $25 that is complete intake manifold " you were lucky my LIM cracked the same way while I was tightening upper plenum.
