Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 06-27-2009, 09:39 PM
GregD1234 GregD1234 is offline
93 Concorde No Spark
I've got a 93 Chrysler Concorde 3.3L and no spark. I've replaced the crank sensor, cam sensor, coil pack. I've verified the timing chain's ok. Now I'm starting to think it might be a bad module. Thoughts?
Old 06-28-2009, 07:01 AM
72mino 72mino is offline
Re: 93 Concorde No Spark
Do you have fuel pressure? Any blown fuses?
Old 06-28-2009, 12:41 PM
Thought of that, fuel pressure was low so I replaced the fuel pump (thank god for the access panel in the trunk) didn't have to drop the tank. So I've got plenty of presure on the fuel rail now. But still no spark. Checked all the fuses nothing blown. including the ones under the hood. No codes except the ones for disconnecting the battery and the 55 end. She cranks but no spark.
Old 06-28-2009, 03:41 PM
Are you sure you installed the crankshaft sensor right. I've read that if you don't push it in far enough before tightening it down; then the spacer doesn't get sheered off and you don't get a signal, therefore no spark. If I think of anything else I'll post. Keep us updated.
Dustin
Old 06-28-2009, 04:47 PM
Got it! I didn't have the camsensor seated far enough in. Wacked the damm thing with a hammer and she fired right up :-)
