Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 06-27-2009, 02:53 PM
sl2frank sl2frank is offline
'94 sl2 electrical problem
I have a1994 SL2 that occasionally, now more and more frequently, has a strange problem. Car usually starts fine after sitting overnight, but after being driven for even a couple of minutes and turned off will not restart. Initially nothing gets power as if the battery is dead, but after a few seconds the hazard, brake, and dash lights flash, even if not switched on and with no key in the ignition, but no power to starter or anything else. After waiting several minutes to an hour the lights stop blinking and everything works as normal and car starts and runs fine until turned off. Note, this happens more frequently during the summer.
Old 06-30-2009, 06:20 PM
RC1488 RC1488 is offline
Re: '94 sl2 electrical problem
Bad ground or bad contact at the battery. Check them all and make sure they are corrosion free.
Also replace your ECTS (with the two wire connector)
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 06-30-2009, 06:32 PM
Will do. Thank you for the response/advice RC1488.
