Go Back   Automotive Forums Car Chat > Cadillac > Fleetwood
Old 06-27-2009, 02:23 PM
ROYZELL ROYZELL is offline
antifreeze coming out of ac drain?
This is weird.. my brother-in-law fleetwood is leaking antifreeze where normally the water drain for the a/c...the inside of the car has a undescribable smell and i have seen and smell busted heater cores...thats what got me... but if anyone might just so happen to know mt problem let me know!!
Old 06-28-2009, 08:15 AM
DFBonnett DFBonnett is offline
Re: antifreeze coming out of ac drain?
I'm not familiar with the under dash layout of the Fleetwood, but I can't imagine what it could be other than a failed heater core. You might want to put a pressure tester on the system to help find the leak.
Old 07-02-2009, 05:49 PM
ronaldk's Avatar
ronaldk ronaldk is offline
the heater core and a/c evap are housed together so if heater core leaks i can see where coolent could run down tube ment for condensation removal. good luck i have changed heater cores on several cars and have only once had a easy time of it. you dont say the year of car but i can tell you the newer ones have special hoses that snap on to both heater core and eng if you have clamp on type get adpt and run hoses together forming loop back to eng for now. at least you will stop leak, that can overheat car. that can give you time to get the heater core replaced. again good luck
