Old 06-26-2009, 07:25 PM
tobbytyler tobbytyler is offline
zc sohc
i have 90 dx crx with a zc sohc with dp-fi i bought it with a problem. it has a sezed cam and broke the timing belt 107 tooth (i'm gussing 1.6) i do not know how this happend but the bottom end still moves free and still has oil in the pan. should i junk it, and go to b16a? remiber dx with dp-fi or put on new head. can replace parts but far from computer genuse or honda tech also not the richest. sugtions will be taken sirus thanks.
Old 07-03-2009, 12:27 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: zc sohc
zc sohc is like a d16a6, stock si engine. except not MPFI.
i personally would not rebuild. the money spent to fix (if even fixable) could have been spent on a d16z6 or d16y8 sohc vtec. if you dont have a lot of money it's your best option as it bolts to your tranny, it's a cheap engine to find, and just needs conversion harness & ecu. b16 you need more expensive engine & tranny, mounts, axels, linkage, harness, and ecu.
you want more power and can afford it go b16. can't afford b16 but want a HP gain i would go sohc vtec....you'll gain like 40+ horses. you're current set-up is basically a dx
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 07-03-2009, 01:32 PM
Re: zc sohc
thanks for the search site and info. i will try to find one of those motors. will the harness out of a hf or si work, and what cumputer will i need. here is a dome quetion what is obdo, obd1, obd2 thanks agine for the help. KTB
Old 07-03-2009, 01:46 PM
amy@af's Avatar
Re: zc sohc
you actually can run it off the si ecu but you won't have vtec.
you will need a p28 ecu and obd-o to obd-1 conversion harness as the sohc vtec is odb-1
Old 07-03-2009, 11:06 PM
Re: zc sohc
thanks agine. i think i have chosen the y8. i found the swap info on AF and found a 99 y8 at a local yard. now to find a si intack, computer, harness. the swap says only one sylniod wire to add, and $325 to have the si ecu re- poped. will the y8 work with the l3-2? thanks KTB
Old 07-12-2009, 06:07 PM
Re: zc sohc
i bought a 91 si pm6 5speed puter out of a civic will this work with a 90-91 crx si-hf harness. THANKS KTB
Old 07-12-2009, 07:14 PM
nathan19 nathan19 is offline
Re: zc sohc
I think it will work... but i'd wait for a more experienced user to give input
Ricer babyyy
