Old 04-02-2003, 01:17 AM
frostee's Avatar
frostee frostee is offline
Send a message via AIM to frostee Send a message via Yahoo to frostee
just gotta hold of some rear discs and sway bars.....
i went to the junkyard and pulled off the whole rear knee assembly w/ the discs and the ebrake cables, along w/ the sway bars off a 92 4 door integra gs..... that's all i need to install it onto my si right, as long as i have all the bolts right? Is there gonna be anything else i'm gonna need to do the conversion??
Old 04-02-2003, 02:13 AM
91civicDXdude's Avatar
you only need the rear trailing arms, the disc brake assembly, the lower control arms, and the sway bar.
Im doing this exact swap as we speak except for i got it off a 91 CRX Si so i'll need to grab me up some integra brake cables..
Old 04-02-2003, 03:14 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
dont forget brake hoses. cause the drum brake ones are too short. and ebrake cables too
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 04-02-2003, 08:33 PM
ev0lution7 ev0lution7 is offline
Send a message via ICQ to ev0lution7 Send a message via AIM to ev0lution7 Send a message via Yahoo to ev0lution7
ok here it goes again
for rear disk conversion u need.....
e-brake cables:
civic HB- integra 2 door cables
civic 4d- integra 4 door cables
CRX- CRX 90-91 Si cables
for trailing arms:
all civic and CRX's use 90-93 teg trailing arms ONLY the trailing arm if you are doing a REAR sway bar upgrade make sure that the lower arm that the sway bar mounts to is the ONLY teg arm that you use or you will have really wacky camber (trust me i have tried teg parts are just a HAIR off)
Brake lines:
all CRX and CIVIC will need new brake lines i recomend steal braided but u can use the teg ones
thats it the swap is pretty striaght foroward
ENJOY!!!!
Crxce- theoretically if u laid a starter on a table and hooked up the wires would it run???
BLU CIVIC- no...it doesn't have any legs
Old 04-02-2003, 08:56 PM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
I just did the same swap last week, it all went perfectly. I bought brand new e-brake cables from ACURA, costed about $80. you need all the hardware for the e-brake cables to connect to the caliper. doing this swap will also change the offset of you suspension. it will put the rear wheels out a bit. my 17's rub now. I just ordered a new rear camber kit so I can put some negative camber on the rear wheels. I am going to do the fronts as well. going to pick them up tomorrow. I'll try to get pics.
when you bleed the brakes at the end of your swap, bleed the whole system clean, you will get a alot of air, bleed all the bad shit out, very important.
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
Old 04-03-2003, 02:17 AM
90hbvtec's Avatar
90hbvtec 90hbvtec is offline
so if ur gonna buy the rear camber kit and negtive it ur gonna eat up ur tires right...cause i might be doin that too i want the rear to camber so that my tires wont rub.....
tru sohc vtec......
d16z6,ractive intake,ractive wires,msd ignition system w/blaster2
obx headers,pacesetter catback, w/test pipe,arospeed bomb muffler,tockico illumina shocks,r1 coilovers,GSR blades rims,ebay short shifter, w/neuspeed bushings,neuspeed strut bars front n back,ingalls camber kits altezza lights,indiglo gauges,proform shift light,integra center console..thats it for now...what else do i need...??ummmmmmm..TURBO..!!!!
Old 04-03-2003, 07:29 AM
91EF3ZC's Avatar
AF Premium User
all I need is like .50-.75 degrees of negative camber. The tires won't get worn excessively, the will wear on the inside first, but as long as the toe is 0 degrees, it will be fine. TOE is the worst thing for excessive tire wear.
ever look at a bmw M3 from behind? look at the 1.2(guessing) degrees of camber it has from the factory. camber is ok in moderation toe is bad.
Old 04-03-2003, 07:38 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
frostee..I got a 91 Integra 3-door over here...i think you need the e-brake cables from that...and I need your e-brake cables from the 4-door...I need to go pull these parts and we then maybe we can exchange cables
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
93 rear strut and sway bar Little red rocket Grand Prix 2 08-31-2010 12:51 PM
Strut and Sway Bars... ricecube77 Suspension 15 10-20-2001 01:06 AM
Strut and Sway Bars DTRsjG20 Classifieds 1 09-17-2001 12:53 AM
Need Strut Brace and Sway Bar DTRsjG20 Classifieds 1 08-23-2001 05:16 AM
