Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 06-25-2009, 07:16 PM
bat27 bat27 is offline
1994 Dodge 15 passenger
After stopping for a short time when I tried to take off the front brakes were locked up and the pedal was stiff. I tried to pump them and move the van back and forth but they wouldn't let go. After setting for about 15 minutes they let go but the pedal went clear to the floor before stopping. This happened once before but over a month ago. The brake light and abs lights have been on for a couple of months but I have only had the problem twice. Could it be leaking fluid and sticking? Vacuum boost? It appeared to be both front brakes at the same time.
Old 06-25-2009, 11:08 PM
alloro alloro is offline
Re: 1994 Dodge 15 passenger
Kinda sounds like the proportioning valve isn't working quite right.
Old 01-11-2010, 11:32 PM
wilguess wilguess is offline
I have found that the master cyl. will also cause this problem.
Old 01-11-2010, 11:35 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Imo the master cyl is the first place to start.
Tags
b3500 , dodge , ram , van
