Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 06-25-2009, 10:55 AM
biturk biturk is offline
2000 sunfire
i got a 4 door 2000 sunfire and it has manual windows and just the key to lock it but i want this things to be powered up and i got questions?
what kind of motor fill fit with a transmission into this without major adjustments?
where can i get power windows, and power door locking system?
where can i get cruise control in my car
i live in iceland and those cars are very rare here so i cant just hope into next shop and buy things into it
any shops i can orrder things from on the internet that do not overprice every single piece they have?
sry about my english, imj starting to get a little rusty in it
Old 06-29-2009, 08:05 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: 2000 sunfire
It will be a nightmare trying to install power everything. Yes there are door poppers, but honestly.... just live with what you have, or buy a new car.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 06-30-2009, 10:50 AM
Re: 2000 sunfire
thanks for the answer but i got the knowledge to do this i just need the parts and i love this car too much to just sell and buy another
beside, no one on iceland ever done anything to a sunfire, i want to change that fact
Old 07-01-2009, 08:37 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 2000 sunfire
You could try www.car-part.com
The cost will add up quick, but they have had every part I've ever looked for.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 07-02-2009, 09:19 PM
Lifted GMT-360!
Re: 2000 sunfire
yup, www.car-part.com
Call up a yard and tell them you want the entire car's wiring harness and all the switches etc... going to run you a pretty penny.
Windows will be an issue tho.
Old 07-03-2009, 06:38 AM
Re: 2000 sunfire
thanks all of you....but why will windows be an issue
Old 07-04-2009, 12:30 PM
J-Ri's Avatar
Re: 2000 sunfire
I disagree about this being a "nightmare", but it's certainly a lot of work. Done properly (to look like it had it from the factory), you have to install new ends in the blank spots in the fuse panel, run wires under the dash into the center console, run wires back out of the console, under the dash, and through the black bendy things where the doors open. I'm not sure where the wires are run from the factory, but I assume you would have to remove the entire dash to use the harness that comes with all the parts. Considering that, I would cut the harness where it's convenient and run new wires up under the dash and then solder the new wires to the old harness pieces. This is also assuming that the power window motor/regulator will fit in place of the manual crank and regulator. I would guess the holes are probably there, but you won't know that until you get the power stuff and try to fit it into place.
I may be wrong, but I think the power door locks are controlled by the BCM on the '00s, I know my '04 is. It doesn't have lock buttons, but the doors lock when I start moving and unlock when I take the key out of the ignition cylinder. It won't have the wires for the lock/unlock at the BCM. If you're good at electrical stuff, you could figure out a way to do it. I think I know how, but I'm not opening up that "can of worms" for you
