Old 06-24-2009, 12:46 PM
anglerandy anglerandy is offline
Driving me crazy
Going to make this as short as possible. 1988 Chevy 5.7 L T.B.I.. New short block with new heads that have better air flow thru intake ports. New plugs, cap, rotor, pick-up coil, ign. module, E.S.C., I.A.C., knock sensor, O-2 sensor, air pump. Base timing at 0'. No vac leaks. Valves adjusted. Fuel P.S.I. good. Dist. bushings good. Wire from knock sensor good. 9 volts to pin B7 on E.C.M..
Still getting code 43 after closed loop and W.O.T.
Also dead spot in acceleration just off idle( sometimes even a back-fire). What am I missing?
Andy
Old 06-25-2009, 04:03 AM
Re: Driving me crazy
What? No super tech's on this site?
Old 06-25-2009, 12:50 PM
2000CAYukon 2000CAYukon is offline
Look at Post #3 in this thread http://www.automotiveforums.com/vbul...d.php?t=954001
//2000CAYukon
Old 06-25-2009, 12:56 PM
Missed the part about a dead spot off idle. Are you sure the EGR solenoid is hooked up right? Stock cam?
Do you have access to a scan tool to see what the sensors are showing? The backfire could mean you are running lean.
//2000CAYukon
Old 06-25-2009, 11:54 PM
Mine is the old vintage with the external E.S.C.. It sends 9.2-9.3 volts to the E.C.M. It is not sensing a knock during the second "Test" that the E.C.U. does and then setting a code 43. I can get it to sense the knock sensor when the timing is advanced so I know that the circuit is good. All other sensors with in range.
When I run the engine on a scanner and run it on the "10k" test which advances the timing as part of the settings, it runs like a race car.
Old 07-29-2009, 11:36 PM
sak22's Avatar
sak22 sak22 is offline
USACMRETVET
Not sure if you've resolved this yet, but you set the base timing at 0'... did you re-connect the spark advance?
2008 Honda CR-V EX-L SE- Glacier Blue Metallic
2007 Honda CR-V EX-L SE- Nighthawk Black Pearl
2003 Honda CR-V EX- Chianti Red Pearl
2002 Chevrolet S-10 LS- Dark Cherry Red Metallic
1989 Chevrolet C1500 Silverado- Custom Black Cherry Metallic
"The Black Beauty"
