Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 06-23-2009, 10:53 PM
deosthali deosthali is offline
Question FUEL Leak very interesting problem
I have toyota corolla 1994.
whenever i full my gas tank after some time I see fual leak starts from front side of the car. The fuel leakes contiues till my gas tank becomes empty.
Point to note: Lately I have replaced my both fuel line. So no issue with Fuel lines
anybody has any idea
Old 06-23-2009, 11:39 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: FUEL Leak very interesting problem
where specifically do you see the fuel coming from?
Old 07-09-2009, 02:37 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
If you try to overfill your gas tank, it can overflow into the evaporative emissions system if the check valve is malfunctioning. Normally only gas vapors are directed from the tank to the charcoal canister, but if the little valve sticks open, liquid gas can go through and saturate the canister charcoal, ruining it. Try to find it in the engine compartment...on the driver's side usually a black plastic cylinder with one tube coming from the gas tank and another going to the throttle body. There'll usually be a vent on top...if gas is coming out of there you're SOL. Had this happen on my truck....what a mess, but didn't drain the whole tank like you describe, just a gallon or two until the level went below the tank siphon tube.
Anything else would have to be related to the fuel lines, fuel filter, etc, that you had replaced. Loose fuel filter line? Fuel line kink or tight bend? Cross-threaded connnection? You'll have to get your head under the hood and look sniff around. Follow the drip path upwards from the ground to see the path the fuel takes from the leak site. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
