Old 06-23-2009, 09:29 PM
mrelmo mrelmo is offline
PO420 ugggh cat or lean
ok it is a 2001 3400 grand am gt, the cat was replaced 4 years ago when i also replaced 2 injectors that were pluged. now i am getting the PO420 code bank 1. i replaced the upstream O2 sensor but nothing has changed. from talking to different mechanics i am told it could be the cat or a lean cyl, without spending $100.00 for a full diagnostic scan, what are my best options
Old 06-24-2009, 08:51 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: PO420 ugggh cat or lean
p0420 is catylst system efficency below threshold.
Did you replace BOTH O2 sensors ?
It sounds like your Cat could be bad, or your down stream O2 sensor.
Theirs a test proceedure here for your O2's.
Tips and Maintenance
1999 Grand Am SS 3.4 OHV
Old 06-24-2009, 10:06 PM
the down stream O2 was replaced with the cat 3 years ago, the test procedure, does it mean unplug the sensor and reconnect the plugs with bare wires that can be probed with a meter, if that is so can i just poke a pin in the wire and connect the probes
Old 06-24-2009, 10:10 PM
secondary question if i have to replace an injector because of a lean cyl can i buy just a plenum gasket or do i have to buy a whole upper gasket set
Old 06-25-2009, 06:02 PM
I would only back probe the plug in. If you perce the wire casing you can have problems down the road with corrosion on the inside of the wire(s).
To replace the injector you only need to pull the upper intake. You might get lucky and not even need a new one if it doesnt fall apart or stick to the LI.
Then you need to releive the fuel pressure, disconnect the fuel lines, and pull the entire injection unit up out of the intake.
You should also replace the "O" rings to prevent fuel from leaking and causing a fire.
Old 02-28-2010, 08:32 AM
Camarogirl77 Camarogirl77 is offline
Did you find a resolve for this? I am having the same problem! Thanks
Old 02-28-2010, 08:45 AM
danielsatur danielsatur is offline
99.9% It's a blown catalytic converter, any muffler shop can do a test for free.
Old 02-28-2010, 10:06 AM
Thank you for the advice. I am going to make an appointment tomorrow to get it tested!
