Scan Tool question!!
I'm looking at the following scan tool.
http://www.amazon.com/Equus-3160-Pro.../dp/B001QIUGVI Does anyone have any comments on it specially about the ABS diagnostics? I'll be using it on a 99 Grand Am SE 3400 and a 01 Grand Prix GT. Thanks Weber |
Re: Scan Tool question!!
It should do OK.
I missed it though, is it just able to retrieve DTC's, or will it also display sensor and data streams? If it just displays DTC's, you can find ones cheaper that do just fine. I have an Acctron just for quick reading and erasing. It does the job.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
This one looks like it does it all. I'm mostly interested in error codes and ABS diagnostics.
The ABS light is on on my GP and all the wheel sensor/bearings are OK, the front ones I've just replaced. Weber |
What are the resistance readings on the back ones? Compare side to side.
If you have that much cash, it would be a nice investment that will save you all sorts of headaches.
Whats the return policy on the scan tool incase your unhappy with it?
