Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 06-23-2009, 02:38 AM
93erTransporter 93erTransporter is offline
Question Auto Lever PSI?
I have a '93 Transport (surprised?), the previous owner had the mechanic alter the leveling system by putting a valve under the bumper to fill the air shocks. The air compressor was shot, so this was an economical fix. I am towing a tent trailer and have to fill the shocks via a gas station, and need to know how much pressure can these shocks take??? Any idea?
Old 06-24-2009, 08:07 PM
Jeffrv's Avatar
Jeffrv Jeffrv is offline
Re: Auto Lever PSI?
I had a similar set up for a while on my van, and was advised to maintain at least 20psi at all times, even empty to preserve the inner seals.
As far maximum, I have used 70 psi, but found 40 or 50 psi was adaquate for a tent trailer and 2 adults.
Jeff
Old 06-27-2009, 05:53 PM
Jrs3800 Jrs3800 is offline
Re: Auto Lever PSI?
Depends on the air shocks you have..
I have a set of Monroe Max Air shocks that are good for well over 100 Psi... The stock system I think maxed out at 70 Psi.. I have replaced the pump on my van as well due to failure of the original..
Old 01-14-2010, 01:12 AM
Re: Auto Leveler PSI?
Jeffrv 06-24-2009, & Jrs3800 6/27/2009 thanks for the feedback. I found with the trailer I put in 80lbs to keep it level and it worked out well. Thanks again, took me a while to get back on.
