Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 06-22-2009, 02:51 PM
vali31 vali31 is offline
97 Stratus not starting
Used the car just last evening, woke up this morning for work and the Stratus would not turn over completely:
> Battery - FINE, voltage was at 12
> Lights Exterior and Interior - FINE
> Power Locks and Windows - FINE
> Wipers - FINE
> FUSES - FINE
> NO LEAKS
.......When I try to start it, it just doesn't turn over completely to start the engine. ANY help would be much appreciated.
> Updated:
Checked for code and got 42:
DRB Scan Tool Display:
-Auto Shutdown Relay Ctrl Circuit
-No ASD Relay Output Voltage at PCM
-Fuel Pump Relay Control Circuit
-Fuel Level Sending Unit Volts Too High (or Too Low)
-Fuel Level Unit No Change Over Miles
Description of Diagnostic Trouble Code:
-An open or shorted condition detected in the auto shutdown relay circuit
-An open condition detected in the ASD relay output circuit
-An open or shorted condition detected in the fuel pump relay control circuit
-Shorted (or open) circuit between PCM and fuel gauge sending unit
-No movement of fuel level sender detected
