Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-22-2009, 05:59 AM
Dutchinohio Dutchinohio is offline
Am I missing anything? Compression issue
OK to review.... 1999 P71 with 160,000 (4.6L)
Compression test results are dry/wet...
1) 130
2) 110/130
3)130
4)110/125
5)110/125
6)130
7)110/125
8) 0/0
We pulled the valve cover yesterday. I found no problems with followers, lash adjusters or springs. I assume a valve needs to be burned, piston holed or gasket blown. I see no evidence of the head gasket being bad. #7 is ok, no coolant loss or leak and no external evidence noted of a problem.
Is there ANYTHING else to check that doesn't involve pulling the head? This is about as deep as I want to go on this car. If I can't fix it without tearing it apart too much farther we'll problably just sell it. Too bad... it's a darn clean car.....
Old 06-22-2009, 06:46 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Am I missing anything? Compression issue
Check for blow-by. Remove the oil filler cap when the engine is running. If a piston has a hole, it will chuff air out the oil filler like a steam engine.
If there is no blow-by, hook a vacuum gauge up to the intake manifold when the engine is idling. Normally the needle should hold steady at 18-20 inches. A leaking intake valve will cause the needle to bounce regularly.
