1994 Pontiac Grand Prix
It is burning way too much fuel and slight power loss but car is still running and starting fine. It eats gas like no tomorrow. Please help any suggestions would be most appreciated!!!!
Re: 1994 Pontiac Grand Prix
What motor do you have?
I would suggest to check fuel pressure key on engine off, and with the engine running. Then I would pull the vacuum line off the fuel pressure regulator and make sure the regualtor isnt leaking gas into the line.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
In addition to above suggestions; do you have a check engine light on (if so what codes are stored), and is the car shifting all the way into overdrive?
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Okay we took it for a test ride after changing all of these things and it is still sucking gas like crazy. Could it be the fuel pump? We have also done a tune up on it. It is running better but still sucking fuel like crazy. Any other suggestions would be most appreciated.
What motor do you have? As Rich asked, is the SES light on?
Next step I would ohm out the injectors to check for any that are shorted.
Thx again for your help. |
in 94 did it have the 3100sfi motor, or the 3.1mpfi?
I know on the 3100sfi there is a large electrical connector in the alternator area, you may be able to unplug it, and text the resistance of the injectors there. You could also rent a fuel pressure tester from advance or oreilley's or autozone and check fuel pressure.
there is generally two ways to chech injectors.
1) injector balance test (requires a spendy balance tester and fuel pressure guage) 2) ohm check them Have you looked for that large connector I told you about? You either have to find that and check them there, or remove the upper intake plenum. I will see if I can find a wiring diagram so you know what wires to ohm check at that plug.
good thought rkvons. Even though its "sucking" gas doesnt mean that the motor is to blame. It could have a trans issues, or maybe the tires are extremely under-inflated.
To the OP:
Please reread all the posts in this thread and answer those questions in which you haven't. In particular, do you feel the car shift through all 4 gears as you accelerate ? We cannot help you if don't answer our questions, and we could continue speculating until the cows come home.
